MS Excel Code ?
samjpullen
Hi guys and gals, i need a little help with a formula.
I need a formula that will do the following.
Some members of a team have a set target of lets say 10 per day, i need a formula that will show me of they are have made there target or not.
e.g i will input figs and then in another box it will show the same amount but in either Red for not meeting targets and Blue for meeting targets.
So if i input 9 it will show in red text or a red backround and if i input 11 it will show in blue etc.
Anyone able to give me a helping hand :)
MDX
graham.myers
That sounds more like a conditional format than a formula and you wont need an extra column
select the cell range where you are inputting the figures. then format > conditional formating.
In there select value is less than and enter 10 in the box. then choose the colour for it. Then select Add>> and add another row which is greater than, and enter 9 in the box and choose the other colour. Hit OK
liveforav
I'm a little bored so thought i'd put together an all singing & dancing option for you.
I've used a bit of formula, conditional formatting and added in the weekly percentage that the target is met.
  • B2:B11 is used to set each individuals target
  • Columns with 'Day # Figures' are used to enter individuals daily figures
  • The '+/- Target' columns are locked as they automatically update
  • The 'Overall Weekly Target Met (%)' column is also locked and will automatically update.
The password to un-protect the spreadsheet is 'Target'
Can you tell I cant sleep??:boring: :boring:
  • DailyTargets.xls
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
