MS DUO or PRO DUO?????????????
Discussion in 'PS Vita Forum' started by reklor, Sep 13, 2005.
Tags:
  1. reklor
    reklor
    Nov 24, 2004
    5,020
    Huntingdon
    +189
    Does anyone know the difference between the 'memory stick duo' and the 'memory stick PRO duo'?
  2. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    Pro's are longer and won't won't in a PSP. Pro Duo's are half the size of a Pro and will work in a PSP.
  3. shirleywhite
    shirleywhite
    Mar 28, 2005
    177
    +10
    I thought all Duos were the half size?
  4. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    Typo. I was up about 5 minutes when I wrote that :)
  5. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,392
    Cornwall
    +93
    The duo tops out at 128mb and is the older version, pro is up to 2gb (with larger one coming).
  6. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +584
    Sony really make things confusing, and all the above replies are confusing, and this may be too :rolleyes:
    As far as I am aware the PRO DUO will be faster (& possibly more expensive) than the DUO types, therefore PRO DUO better for movies on memory stick! I dont think you would get any benefits using PRO DUO for music etc, although Sony managed to make their own music format (ATRAC) incompatible with PRO DUO sticks unles you upgrade your PSP software to version 2.0 :suicide:
    Having said all that are there any major price differences between PRO DUO and DUO?
    The whole memory card situation is a mess, Sony has at least 4 versions of memory stick, and then we have all the other manufactuers with there own types :suicide:
  7. reklor
    reklor
    Nov 24, 2004
    5,020
    Huntingdon
    +189
    Thanks for that. I think I understand now..... :eek:
    :D
