MS Autoroute Pushpins onto TomTom
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by thefibreguy, Jan 15, 2008.
  1. thefibreguy
    thefibreguy
    Chaps,
    I am a contractor working for BT. I have been given a PC zip file, which when opened in MS Autoroute, shows all the BT sites in the UK. I have been using my laptop as my SatNav.
    I now have a TomTom. Is there a way of extracting the BT site location etc info out of the zip file, & uploading them into my TomTom POI's.
    Any advice would be great.
    Regards,
  2. Ecom
    Ecom
    Hi there,
    There is a little free utility that can convert Autoroute Pushpins (*.csv) files into TomTom (*.ov2) called POI Converter, link as follows:-
    http://rjdavies.users.btopenworld.com/html/poiconverter.html
    There are also many other utilities for POI's that you may also find usefull on the site, good luck.
    Alan
