MS 905C and 905A - what's the difference
Discussion in 'Home Cinema Speakers' started by theo cupier, Dec 29, 2004.
  1. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    this question is probably as quick as it is stupid, but:
    On RS they advertise the MS905C Avant (£120). On Peter Tyson they advertise the MS905A (£same).
    I saw a 'for Sale' thread here from a while back where someone was selling a 905C described as 'not the avant'.
    Main question is: What is the difference between the Avant and non-Avant?
    Can they be told apart as simply as whether it is labelled 905C or 905A in listings?
    I'm planning to pair a 905 with a 309 sub, from a DSPE800. Rest of the speakers are a bit of a mishmash (Rogers LS4a front L/R and wharfdale diamond 7.1 rears) but this will improve as budget allows... seems like the MS will be a reasonable tone match for the LS4a powered by a B1 amp (relaxed and transparent).
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    The old 905C was the Declaration Series [now discontinued] and I would've thought the C just stood for Centre. The 905A is from the newer Avant Series with uprated drivers and slightly different look to the speaker.
    RS and PT are selling the same speaker, just RS using the older model number and putting Avant after it.
    Tons Of Fun would give you a better answer to compare the two but I believe he's not back until next week.
  3. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    quick bump for the attention of Tons, since he's clearly not 'not back until next week'
    :D
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,944
    2
    +3,311
    What Mal said :laugh:. If I were feeling especially cynical I 'd suggest the codes are deliberately diffierent to try and avoid pricematching.
