MS 902i or MS904??
Discussion in 'Home Cinema Speakers' started by willygbr, Mar 18, 2006.
  1. willygbr
    willygbr
    Hi Guys,
    To complete my system I am looking for some fronts. My Premiere 302's will become my back surrounds. Have the 905i as centre. Can pick up the 904's for £139 or the new 902i's for £150. I know the 904's are floorstanders. Any advice on the subject???
    Cheers,
    Iain:cool:
  2. Upgrade King
    Upgrade King
    Aug 8, 2004
    169
    16
    I used to own the 904's myself as part of a surround system and they were fantastic sounding speakers, easily worth the money, i would pick these as the front soundstage will be larger, it depends if you can accomadate them in your living space.
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    You can get 908s for £299 from hifibitz (down from £499) ;)
    At the prices you've given I'd go for the 904s.
  4. willygbr
    willygbr
    Thanks guys. So even though the 902i's have newer technology you would still go for the 904's? My living space is about 4m by 4m and my present fronts are 3.3m away from listening area. The floorstanders if I decide to go down this route would have plenty of room to breath.
  5. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    I'd guess the 904s would be best, out of your options.
    The 902i go down to 55 Hz, whereas the 904 go down to 50 Hz.
    As has been suggested, the 908s would be better, they go down to 35 Hz.
    Bit of a jump in price, but you get another 2 * 10" woofers :smashin:
    I guess you'd need a fairly meaty amp to drive them though.
    I don't think the newer technology is vastly different, certainly comparing the 902 to the 902i, there are tweaks, but the spec remains the same.
    Ed selley is the man to ask.
  6. willygbr
    willygbr
    Thanks Badger,
    Any others have some advice??
    :lease:
  7. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Why don't you got to Richer Sounds and have a demo? The centre is the most important bit, I'd for for floorstanders unless space is an issue?
  8. Beobloke
    Beobloke
    Aug 10, 2004
    1,315
    Out in the Sticks!
    +67
    The 'i' series are a considerable improvement over the older Avants so i'd go for a pair of 902i's - don't forget to budget for some stands.
  9. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Beobloke- have you heard them (or any of the other i series)? What have they improved?
    Thanks.
  10. Beobloke
    Beobloke
    Aug 10, 2004
    1,315
    Out in the Sticks!
    +67
    I've heard the 902i's and 904i's and in both cases they sound like more "expensive" speakers than their predecessors, for want of a better description!
    Detail is much improved, treble is smoother and they make the original Avant versions sound rather harsh in comparison (which they're not!). Bass is also much improved on the 902i in particular.
