MS 309w problem
Discussion in 'Subwoofers' started by Nokmondoo, Dec 28, 2006.
  1. Nokmondoo
    Nokmondoo
    Jan 22, 2006
    1,816
    +98
    Hi, my 309w has stopped working! I hasn't been used for a few months while i've been decorating and now it won't work. The lights come on but no sound. I've tried changing the sub's fuse but still nothing. Any ideas?
  2. Dodgy_Geezer
    Dodgy_Geezer
    Mar 22, 2003
    2,670
    London
    +296
    When you say stopped working you mean no sound? Have you checked the usual suspects?
    1. Cable from amp to sub
    2. Output from amp to cable
    3. Gain and/or volume on sub/amp
    Regards,
    DG
  3. Nokmondoo
    Nokmondoo
    Jan 22, 2006
    1,816
    +98
    hi, yeah i've checked all of them, i tried my my old eltax sub and that worked ok???
  4. Art Vanderlay
    Art Vanderlay
    Apr 9, 2003
    87
    +3
    My new 309W which I got from TribalUK has exactly the same problem. And as with you, swapping back my old sub proves the output from the amp is OK
    I am now going through the hassle of trying to get hold of Tribal for a refund or exchange - the last email I sent them took over a week for a reply
  5. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    quick one,
    i also got one from tribal, i find that i need the gain dialed up more than im used to, turn it up to just over 3/4 and run something with some bass,
    i thought mine wasnt working at first my kef i had dialed up about 1/4 so naturally done the same noticed nothing,
    then put it up over 3/4 left war of worlds on in background and forgot about it whilst i was doing something else then my frigin living room started to rumble lol, went in it was the scene where the machines first start coming out of the ground lol.
    so put your volume/gain up nearly all the way, let your amp do the rest
    does it work?
  6. Art Vanderlay
    Art Vanderlay
    Apr 9, 2003
    87
    +3
    I tried it with the gain at the max but no joy when outputting a test tone on the amp
  7. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    it is connected to the line IN left/right?
    not the line OUT?
    silly question but you never know and they are all next to each other, working in tight enviroment might of made a mistake?
  8. Sephiro
    Sephiro
    Jul 19, 2005
    455
    28
    +99
    I had the same problem with the first MS309 sub I had. When I turned it on when I first got it you would hear the relay click after a couple of seconds and the sub would work fine, but after a few weeks this changed and the relay would click as soon as you turned the power on at which point I couldn't get any sound out of it.
    Thankfully because this happened a couple of weeks after I had bought it I was able to take it back to RS and switch it for a new one which has been fine since (although I must admit I don't turn it off very often these days in case it happens again :) ).
  9. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    any harm in keeping a sub perm on?
    what sorta power consumption are we talking here also?
  10. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I had a 309 and kept it on all the time with no problems what so ever. My PB10 is always on as well with no problems either.
  11. keyboardman
    keyboardman
    My 309 has been on for about 6 months now, and there has not been any problem.
    And because it has a class D amp i think the power consumption is low.
    You can have a look at the manual.
    Hope this helps
  12. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    cheers guys
  13. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    When I got my 309, it worked for a while and then stopped. I went beck to the dealer, who told me MS fitted the wrong fuse to a lot of their 309's. I tried changing the fuse, which did nothing. In the end the place I bought it from (Peter Tyson) were very good and sent me a fuse, which worked perfectly.
