ms 302's with denon 3802 mismatch?
Discussion in 'Home Cinema Speakers' started by scouse, Aug 23, 2004.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    Would the MS Premiere Plus package be a mismatch/not enough for the Denon 3802, with music and movies a 60:40 split...
    my head is in a spin with all the options out there... some help would be appreciated :confused:
    i have considered getting 902 avants for the fronts instead of the 302's that come with the package ...? would there be much improvement?
    :eek:
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,712
    Upping to the 902's is an improvement for music and a small upgrade for films. The 3 inch and 5.25in drviers are designed to have the same tonal character as each other so they should match quite nicely. It isn't too big a price hike so you might want to try it on the understanding you can get a refund if it isn't worth it.
  3. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    so you think the speakers are a worthy match for the denon?
    thanks for your input tons...
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,712
    I have an unavoidable bias in this regard but the demo's we used to do at shows with the Premiere and the Marantz SR7300 (roughly comparable) sounded good and didn't embarress either component.
  5. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    that's good to hear... just have to save my pennies and hope the deal on the premiere plus package holds till mid september!!!
    do the 302's need a lot of space behind them?
    I ask because i will have an odd room setup being that a computer monitor will be in one corner and bed/seat in the oppposite corner around 4-5 metres away...this means the surrounds will be close to the wall to be sufficiently far away from the listening position...
  6. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,712
    No they are infinite baffle and can go right against a wall if necessary. The 902 has a bass port and needs some room however.
  7. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    no probs... should be plenty of room for the fronts
    thanks for your help... questions are always buzzing in my head, it's nice to get answers to some of them :)
