MR question for Pio XDE owners
Discussion in 'Plasma TVs' started by ikon66, May 28, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    I'm in the process of setting up my 435xde on the pdkfs04 stand. Pioneer have supplied a bracket which enables the media reciever to be placed on its end behind the display, qiute good I thought as it hides away box and cables.
    But how will the remote work if it cannot see the box, will it get its instructions through the sensor on the panel?
    Anyone wanna try covering the front of the media box to see if it works please.
    Paul
  2. Drd
    Drd
    Jan 22, 2005
    1,817
    Approaching the doghouse at great speed
    +246
    The media box has no sensor,trust me.Hide it away anywhere you like.
    Regards
    Ian
  3. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    cheers :D
  4. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    the sensor is in the screen not the media box, so you can have the box outos sight and it will still work.
    This is because the sensor is in the screen and when you use the remote it goes from the screen down the cable to the media box.
    Geat idea don't you think.
    :thumbsup:
