MR for Ronin M110 ?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by david park, Dec 30, 2004.
  1. david park
    david park
    Anyone know the hack for this please for portable DVD Ronin M110.
    Or another make/model which is the same.
  2. david park
    david park
    Got the hack, I give it below in case anyone ealse needs it.
    1. make sure there are no discs in the machine
    2. Type 9735 on the remote and this should bring up the region menu
    3. Choose the region (region 0 for multiregion) and click play on the
    remote to confirm your choice
    Many thanks to www.3wisemonkeys.co.uk and thier product description.
