mpman player mp-f1000 help
Discussion in 'Headphones, Earphones & Portable Music' started by ewin, Jan 18, 2005.
  1. ewin
    ewin
    Feb 25, 2003
    123
    16
    scotland
    Goty this for xmas and poped the cd in the pc and install it but can not find any instruction manual that is on the cd.
    The second question is that the player mixes up and plays album tracks in the wrong running order.
    instead of 1-2-3 and so on it plays like this 8-7-1-2-3-6 ,why?.
    As i have spent a good few hours typeing in track name of albums to be played wrong ,but play in the correct order on the pc.
  2. wormster
    wormster
    Yeah I had this problem.
    what os are you using?
    I found that with xp if you open up my computer and then open the removable drive for the player, then create folders for your albums, then using media player 9, copy the cd into the hard drive, then get the album info off the net, then copy to your player tracks will play in order.
    do you know how to skip tracks without hvaing to hold down the skip button and go through each track?
