MPEG4Modifier - How to get rid of...
aligamer
How do you get rid of the windows login prompt when you boot up? As it appears at each bootup now. Net 1.1 framework was required to be installed along mpeg4modifier.
Also a ASP.net user account is created when i check the user accounts section. I wanna get back to booting straight to desktop, if i delete the ASP account will this be ok and modifier will still function? Or any other ways? Advice pls.
cheers!
Update: All sorted now, didnt need to use powertoys (very hand it is tho) - cheers!
KraGorn
I think this would be better off in the PC forum. :)
There are several tools which'll allow you to auto-login, the one I use is TweakUI off M$' site, look for TweakUiPowertoySetup.exe, it'll let you change many settings in the registry, including the account to log into.
