MPEG2 Software decoder.
Discussion in 'General TV Discussions Forum' started by Znook, Jun 27, 2004.
  1. Znook
    Znook
    Jun 20, 2004
    94
    11
    Red Rose County, England.
    +6
    Hi guys
    I've just spent the best part of the day downloading the HD football clip from EURO1080i. When I try playing it back using RealPlayer it says I need to install an MPEG2 software decoder. Can any of you people recommend one, preferably free! Thanks in advance.
    Rob
  2. encaser
    encaser
    Mar 15, 2001
    2,369
    116
    Suffolk/Essex
    +520
  3. Znook
    Znook
    Jun 20, 2004
    94
    11
    +6
    encaser, thanks for your suggestions. In my eagerness to view it late last night, I'd completely forgot that I already had VideoLAN installed. I've just played the clip and it's definately whetted my appetite to get HDTV ASAP. The detail is incredible. Once again thanks for your help.
    Rob.
  4. mallet
    mallet
    Dec 20, 2002
    180
    +14
    Was this a clip you dled from EURO1080.tv?
  5. Znook
    Znook
    Jun 20, 2004
    94
    11
    +6
    Yes, via emule. It took the best part of the day (for 204mb). I'm tempted to d/l the full 16gb demo but my ISP would probably throw a wobbly :laugh: !
  6. encaser
    encaser
    Mar 15, 2001
    2,369
    116
    Suffolk/Essex
    +520
    No problem Rob;)
  7. dvdmike
    dvdmike
    Nov 30, 2003
    853
    96
    +798
    where did u get the dl from got a link?
  8. Znook
    Znook
    Jun 20, 2004
    94
    11
    +6
    dvdmike. first get a binary loader software package like emule http://sourceforge.net/project/showfiles.php?group_id=71866
    install, then run the software, select connect, then do a search for 'euro1080'. select the hdtv euro1080 fussball file (normally the top most entry), right click and select download. use videolan (or other viewer) to view once downloaded. away you go.
