mpeg to jpeg
py6km
Jordan Stone
I just wanted to make a quick post to distance myself a little bit from posts above. I’m Jordan and work with PriceRunner. The previous post was from an Intern using my alias and trying to be helpful. He had the best of intentions but, well, in the end he dumped a bunch of links and spammed you.
This was bad, and I’m sorry. Thanks for lettnig me know.
Steve Zissou
hmm... a quick click on "view other posts by this user" shows that you are a spammer. But thanks for the lie.
Gow87
did anyone answer the question here? surely you can just rename the file with.jpg at the end? if this doesnt work go to tools folder options > View and untick "hide extensions of known files" then try it
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
