MP3s already prepared
Discussion in 'Headphones, Earphones & Portable Music' started by Gooner71, Jul 25, 2005.
  1. Gooner71
    Gooner71
    Mar 16, 2004
    61
    East Grinstead
    I'm planning either an iPod 60 or Sony NW HD5 30GB in the next couple of weeks. One aspect which may be a factor is that I've already ripped 26gb of CDs to my PC using Windows Media Player 10.
    Please don't tell me I'm gonna have to redo this whole exercise with either SonicStage or iTunes!!!!
    I'm probably gonna go with the iPod purely on the basis that there are more gadgets for it than the Sony such as Speaker Stations and Car Hifi stuff.
  2. jack190
    jack190
    are the files stored as MP3 or WMA? as i have heard there are problems converting some WMA files with the Sony software.
  3. TheBigLebowski
    TheBigLebowski
    I-pod doesn't support WMA. HD5 Does.
  4. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,470
    iTunes will allow you to convert all the tracks to AAC when you import them
  5. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    As the title says, MP3s already prepared, then you're fine in whichever you opt for - as an iPod (40 GB photo) user, it's the de facto mp3 player for a reason......the best user interface and transfer software bar none.
    Pretty much just like OS X then! ;)
    Edit:
    As both are loseless codecs, then leave as mp3s rather than degrade further by converting to AACs, which only the iPod can decode. There wouldn't be any justification for converting to AACs to reduce space on iPod and PC's drive, as the sound would take a hit.
  6. city
    city
    Feb 18, 2005
    115
    +12
    You can buy HD5 30Gb from Dixons for £179.98 plus £9.99 delivery.
    Same cost as 20Gb model product code 503532
  7. Gooner71
    Gooner71
    Mar 16, 2004
    61
    East Grinstead
    Yep all the files are in mp3 128kbps I think. So I should leave them in mp3 and not convert to AACs - seems reasonable to me cos I'll still be able to play them on the PC.
    Thanks for the help...
    Simon
  8. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    As they are already at 128, any further conversion to another type @ 128 will make them sound worse than better, and the space saving is minimal really.
    Depending on the type of music, I'd say you should have opted for 192 constant, not variable BR for the best compromise between sound and size. VBR isn't recommendsed as more power is needed to process, in the same way using the EQ, backlight, etc does.
