Mp3
Discussion in 'Blu-ray & DVD Players & Recorders' started by atomant, Mar 10, 2001.
  1. atomant
    atomant
    Feb 3, 2001
    9
    England
    Can any body help? I have a LOGIX3000 DVDPlayer which supports MP3. What I want to know is that when I copied MP3 files to a blank CD I used direct CD, should I have used data CD (CDCreater 4 Delux).
  2. bonzo
    bonzo
    I had one of these logix3000, wouldn't play any of my MP3 CD-R so sent it back (picture quality from DVD was poor too).Tested same disks on LG3350, worked fine.
  3. Guest
    You are better with eassy cd creator 5 platinum it gives you the options for creating mp3 discs for mp3 machines
