MP3 to ringtones
Discussion in 'Mobile Phones Forum' started by phenom2003, Jun 3, 2003.
  1. phenom2003
    phenom2003
    Is there any software avaliable that can convert mp3/cda/wav files to ringtones?
    Also are there any phones avaliable where you can put an mp3 file as your ringtone other than the nokia musicphone which is still unavaliable.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    New Siemens phones like the SL55, S55 and C55 can use midi and mmf files. It's possible to convert .wav to mmf (and consequently mp3 and cd too) :)
  3. Jamsie
    Jamsie
    I personally just use soundforge 6 to record the Bit of the cd track/mp3 or whatever i wanna use, then save it at the required sample rate.
    Thus i dont need to send it through PCsuite to convert it.
    jamsie
  4. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    there are a number of phones that play mp3s as ringtones - nokia 3650/7650 and the sony P800.
    Gary
