MP3 to DVD
Discussion in 'Headphones, Earphones & Portable Music' started by shadowritten, Aug 19, 2005.
  1. shadowritten
    shadowritten
    Probably going to win award for thickest person in here today, but here goes ...
    Want to get a DVD reader/rewriter - don't mind if it's external, btw - so I can archive MP3s and other music files. So, two questions:
    1) What on earth should I be looking for, spec-wise
    and
    2) Is it possible to back-up MP3s to a DVD? Will they work?
    Go on - let me have it ... :suicide:
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,236
    +6,445
    Sure. Treat DVDs like a external HD. If anything happens to your PC HD, get the songs back from your DVD
    As for a DVD player...faster speeds doesn't mean best - there is a greater chance of a error. About middle 16x is OK
    Dual layer = 8+ gb of data, but DL discs are more expensive than normal ones
    If you're clever, buy a external HD instead or cheapest brand 40-60gb player and use that. Then you can have your music in lossless
  3. shadowritten
    shadowritten
    Cheers for that. I was somehow under the impression DVD-R/RW could only be used for image-based files.
    Learn something new every day ...
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,236
    +6,445
    Nah you can put anything on DVD unless its got some sort of copy protection
