MP3 Player help
Discussion in 'Headphones, Earphones & Portable Music' started by Axel40, Apr 17, 2005.
  1. Axel40
    Axel40
    Apr 17, 2005
    2,591
    London
    +272
    Hi Guys,
    I hope this is the right place to post this, I am buying my first MP3 player soon, but before I do I want to make sure I get the right one. I have looked and have seen they range from £24 - £200+ I really don't want to go over £80 for one and have found one the, Ministry of Sound: MOSMP020 for £60. The most important thing for me is sound quality, I don't want to buy one that is tingy. I want one that has good sound volume and base. Is this a good make or should I avoid it, maybe you can give me some tips as I am so new to this and can you recommend any?
    Thanks.
    Margo.
