MP3 Player for Windows 98?
Discussion in 'Headphones, Earphones & Portable Music' started by RB05, Jul 24, 2005.
  1. RB05
    RB05
    Hi! Anyone know a good 20GB (or thereabouts) MP3 player that I could use on Windows 98 (not the second edition, just the basic first one)??
    Cheers!
  2. RB05
    RB05
    Anyone?
  3. HMHB
    HMHB
    Nov 11, 2001
    25,513
    Nottinghamshire
    +3,850
    I think you are going to have problems with Windows 98. The USB support on that version was dodgy to say the least !
  4. RB05
    RB05
    Cheers for the reply, what do you mean by support for the USB? I assume my USB is 1.1 or whatever, so wouldnt this do?
  5. clivem2
    clivem2
    Most USB devices only support Windows 98 2nd edition. W 98 1st edition USB didn't work reliably.
  6. HMHB
    HMHB
    Nov 11, 2001
    25,513
    Nottinghamshire
    +3,850
    Correct. I wouldn't advise anyone to use W98 if they want reliable USB performance.
  7. RB05
    RB05
    I had a Sony MiniDisc player Net MD until recently and that worked fine with 98?
  8. clivem2
    clivem2
    It may work but you'll be on your own if it doesn't. First of all you could download Sonicstage to check if it installs ok.
