MP3 Player But No PC ?
Discussion in 'Headphones, Earphones & Portable Music' started by Walton Goggins, Jan 3, 2005.
  1. Walton Goggins
    Walton Goggins
    Aug 25, 2004
    29
    3
    I am thinking about updating my minidisc portable to an mp3 player.
    Usually I record onto MD using a portable cd player.
    Do any mp3 players let you connect directly to a cd player to copy tracks or is a pc definitely needed ?
    I'm not bothered about titling or playlists and stuff, just want the music ???
    I've looked around but am still unsure, a guy in currys said ministry of sound make one but he couldn't tell me the model as they don't do them.
    Thanks a lot ! :thumbsup:
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    Yes you can it's called direct encoding like the i-audio M3 see on web page http://www.jetaudio.com/products/iaudio/m3/ about a third down.
    There must be others as well, check for line in connections and direct encoding as features.
  3. Walton Goggins
    Walton Goggins
    Aug 25, 2004
    29
    3
    Thats exactly what I needed.
    Thanks very much Stevie. :thumbsup:
  4. AntF
    AntF
    MPMan do at least one that has direct encoding Model FOP-8 - looks a bit like a smaller black ipod - bought one for my son from Dixons - now 30 quid cheaper at £99 - pretty good though as it has a radio and decent equaliser settings. 256mb.
    Apple are rumoured to be bringing out a solid state type of MP3 player but I have seen nothing confirmed yet.
  5. inventor
    inventor
    Nov 29, 2004
    33
    My iriver H120 can be used to directly record and encode music from its line in socket to MP3. You can select the encoding rate. Of course, if you're recording a cd then the whole cd will be saved as one MP3 file, although I suppose you could record it as separate tracks by physically pausing the CD and stopping and starting recording after each song. As Andy would say, bit of a kerfuffle, but if you simply want the music and don't mind recording a whole Cd at once the quality can be good. The line-in doubles as a standard analog input or an optical input.
  6. Walton Goggins
    Walton Goggins
    Aug 25, 2004
    29
    3
    Thanks AntF and inventor
    Will look at these as well :)
