MP3 how long on 64mb ..
F
Feersum enjinn
In full quality i assume about an hour, but the next quality down form that -
(1) how long would i get on the 64mb
(2) will tehre be a large noticable drop in quality
WhyAyeMan
At 128k you can expect roughly 64 minutes for 64Mb file size. The same file size would give you roughly just over 40 minutes for 192, about 32 minutes at 256 and probably around 25 minutes at 320K.
I regard 320K as more or less full quality to the original, though it is possible to make reasonable sounding 128 files if you use a good ripper. Anything less than that will be noticably poorer IMO, but I suppose it depends what you use to play them back with.
