MP3 HIFI Hook up
Discussion in 'Headphones, Earphones & Portable Music' started by Eoghan, Mar 14, 2005.
  1. Eoghan
    Eoghan
    Hi Im considering purchasing CreativeZen Touch
    40Gb MP3 Player. Im complete beginner at setting
    up. Will this mp3 player connect up to most leading
    brand seperate systems and let me play it though
    that?? I want to hook it up to a home entertainment
    system
    cheers
  2. Calza
    Calza
    Mar 6, 2005
    93
    i was able to hook my hd3 to a bose cd/radio. u get a minijack and put that into ur mp3. the minijack has to have a white and red plug then u put the leads into thr minijack and then into ur separates it shuold work
  3. MEGAginge
    MEGAginge
    You need a .35 phono > ???SRL??? (not certain on that but err..) lead IE a headphone jack into a red/white stereo jack. You also need to have spare inputs on the HiFi. Most likely they will just look like 'speaker ports' on your hifi - but they will be for input not output. Make sure you have these before bothering to order cables.
    Pretty much any specialist HiFi shop will have the leads you need (general ones wont... SOME Dixons might but they will charge a bloody fortune for the pleasure if they do)...
    If you dont have spare inputs for the cabling, a poor mans alternative would be a .35 > .35 male/male end - which you could plug into a microphone jack on the HiFi. Sound quality would be dismal in comparison though.
    Hope that helped you out.
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    It depends what line in/aux in your hifi has. You will either need a 3.5mm jack to 3.5 jack, or a 3.5 jack to phono lead. You can get them at Argos!
  5. ilindsay
    ilindsay
    Argos - or B&Q would probably have them as well.
    Probably not worth spending a lot on an interconnect. Once you play mp3 through a separates system, you will notice the sound compression.
