mp3 help!
Discussion in 'Headphones, Earphones & Portable Music' started by spidermanalf, Oct 13, 2003.
  1. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    I have done a search and it brought up a million results!
    I used to use musicmatch to =convert stuff to MP3, updated to XP and it won't let me!
    It plays my cds fine, but as soon as I got to
    - File
    - Convert
    and the drive D (my cd drive) and choose wav, and converted them. Now it does not read any files on the cd.
    If its any use its version 8.0 please help, I have just bought a load of cds, and want to listen to them in the car!! GRARARARAARRRRRRRRR
    PS just found all my cd tracks are now called xxxx.cda, whats that??
    Sorry for been completely dim!
  2. Frankie_D
    Frankie_D
    Oct 19, 2003
    180
    Surrey
    Im not sure whats happened here but musicmatch has many problems. A better application to use would be the new windows iTunes that Apple just brought out. Its alot simpler than Musicmatch and less buggy too. So if you dont mind changing you can go here to download it:
    www.itunes.com
    Thats all i can do to help since im not too great at windows (i'm a mac user)
    Frankie.
  3. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    Cheers Frankie,
    All my cd tracks are now .cda
    And I cannot change them back .wav!
    GRARARARRRRRRRR I'll try iTunes.
  4. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    hiya
    audio cd tracks are .cda you will need to convert the contents of the album to .wav's to actually have wav files. it isn't just a case of adding the file extension i'm afraid. :(
    but from what i gather you are trying to do, i would just convert the cd tracks directly to .mp3's if i were you. exact audio copy is a good program for doing this :)
    also, as Frankie_D says...you could always give iTunes a bash. i'm yet to try it but think i will any day now [hoping to get an iPod one day :)]
    i can but dream
    monsieurblack
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I use dbpower amp ,do a search on google,it converts everything.
  6. fred123go
    fred123go
    Sep 16, 2003
    1,044
    39
    Cobham, Surrey
    Cheers Franny D for the contributions!!!helpful as ever!!!
    F
  7. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    Thanks guys much appreciated!
  8. diesel_uk
    diesel_uk
    a program called "cdex" does the job fine. Its a converting program and should help you with your problem i hope.
  9. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    np matey :)
    hope you got it all sorted
    take it easy
    monsieurblack
  10. Frankie_D
    Frankie_D
    Oct 19, 2003
    180
    Surrey
    Yeah its no problem if theres anything else then just make a thread and ill be happy to help.
    F.
  11. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    A free one that I always used to use (as it is a ripper, converter and ID3 tagger in one) is CD'n'Go. It can be found at www.download.com
