I am just in the process of getting into MP3 now that I have a capable player in my car - only a few years behind the times, right?!
I have used Audiograbber to extract 100 tracks from various CDs and Acoustica MP3 CD Burner to sort and burn them, but all the tracks are separated by a moment's silence. This is no problem on a standard CD, but forty or so of the tracks are from a continous mix CD so of course it sounds crap with gaps.
Should I have done something in Audiograbber to eliminate these gaps, or in Acoustica? I see there is a setting in Acoustica to eliminate gaps if their combined size is over X.X seconds, but if I set that to zero, won't it join ALL the tracks, whether they were meant to be joined, or indeed whether I want it to or not? What setting/stage of the process have I missed?
Also the Acoustica is onyl a trial - is there a better app out there for the creation and burning of MP3 CDs?
Thanks for looking - sorry if this is SOOOO obvious to you all
dr_m
dr_m
