mp3 head unit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by vik, Sep 18, 2003.
  1. vik
    vik
    can anyone help... i looking for an mp3 head unit in my car.... cheapest one i have seen so far is panasonic CQ-RDP383 for £110 (inc del from letsbuycaraudio.com)
    Any of you used this site before? are they ok? do you know of any cheaper deals out there?
    I dont want to spend too much money on it - but want one that sounds reasonable - i was making the assumption that it will sound good as is an ok brand! my car speakers arent great (old audi a6 - factory fitted nokia speakers - which i am hoping to change one day!!!!)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    sony cdxmp40 available for £125 ish and there is a panasonic at the same money
  3. tvr
    tvr
    Aug 21, 2002
    434
    Bucks
    +4
    I have the Sony cdxmp40, as mentioned by hornydragon.
    I am very happy with this budget headunit.
    You can burn an MP3 CD and navigate through albums/folders etc.
    A good choice!
  4. Hugh
    Hugh
    Mar 31, 2003
    2,150
    116
    Birmingham
    +1,182
    Vik,
    The Panny can be had from incarexpress.co.uk for £99.99 plus about 6 quid P+P.
    I've just ordered the Pioneer 3500. £130 including VAT & Delivery. Due to arrive in the next couple of days. Cheapest by some way and they don't seem to be going over the rop with an inflated P+P price.
    The Sony is the same price as the Pioneer too.
    Oh, and I have no financial or otherwise interest in their site other than passing on a tip.
    Enjoy.
    Hugh
  5. mre15
    mre15
    Mar 15, 2003
    623
    28
    Gloucester
    +35
    One thing worth noting is that the panasonics also play wma files whereas I think none of the others support them.
    I bought my nice panasonic 983 from here http://www.mcs-direct.co.uk/index1.asp
    Good luck with your shopping
  6. neilybealy
    neilybealy
    Jul 9, 2001
    1,539
    48
    Kent
    +55
    i'm considering getting an mp3 unit to replace my sony but i heard someone say that most mp3 players will pause for a few seconds inbetween tracks?
    is this the case with the players mentioned above?
    it would be really annoying trying to listen to a dance cd where each track is mixed into the next but you get a 3 second pause whilst the player is reading from the disk
  7. vik
    vik
    dont think it does... when u burn using nero then u can choose to put in the gaps
  8. Ayub
    Ayub
    Oct 15, 2003
    6,401
    Bradford
    +580
    Vik which nero?
  9. vik
    vik
    i use nero express - there is a box that says no pause between tracks - i have never used it though!
  10. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    If you are burning mp3's to cd and putting a pause between tracks or not (depending if u tick the box) ...it means you are burning the mp3 files as audio cds and not mp3s.
    mp3s files are just data and as such a pause does not apply to them. A computer (or headunit) is just reading the data and decoding it. It is not time based as per a audio track on a audio cd. If you are writing mp3s (nero converting on the fly to audio cd format) then you can of course add a pause or not, up to you. So it will record the mp3 at e.g 3.43 and 2 second pause (standard) as requested.
    Vik, do you want a headunit that can play mp3 files or a headunit that can play copied audio cds ? (i.e 10-12 tracks per cd or 40+ tracks per cd) ?
  11. Jamp
    Jamp
    Aug 8, 2003
    76
    Sheffield/N Wales/Isle of Man
    I've got the Panasonic unit, £100 from MCS Direct. It does what I wanted (WMA) but it isn't perfect. You get a slight pause between tracks (only noticable if the two tracks are mixed into each other to make them seamless normally) but it's only a fraction of a second and doesn't really bother me much. What is annoying is how long it takes to load an MP3/WMA CD, must be about 20 seconds. It has to start again after it looses power while you're starting the engine, if you've been waiting for a passenger or whatever and left the ignition on 'electrics on'. It also looks/feels a bit tacky and flimsy, never had a problem with it though. Also I like the fact the display just gives you text, no silly dancing graphics to distract, although it is a bit bright for night driving. Sound quality seems fine, mine's an Impreza that previously just had the standard headunit, this unit has given a big improvement even with the standard speakers.
    I'd say it's good value, and I'd buy another, just be aware that you'll find a few flaws.
    Good luck,
    Ben
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Just to let you know i used mcs-direct for a sony hifi for my sister service was great and have no hesitation in reconmending them to you. will be ordering an MP40 soon just hoping to see a price drop first!!!
  13. wozwebs
    wozwebs
    Jul 10, 2003
    1,165
    +112
    I purchased the Kenwood KEN-KDCM4524G from Car Audio Direct
    http://www.caraudiodirect.co.uk/pro...=1986&osCsid=5744b63f39ae934b3f0ec0fce46aa9c3
    It's a fantastic player and very quick when accessing MP3 tracks. The pause between tracks is less that half a second and it displays the track names via the ID3 tags. Sound is excellent too and you have the option later on to add a DAB pack.
    No WMA support though which is only a minor thing for me. Great price and fast delivery also.
