MP3 file Compression
Discussion in 'Mobile Phones Forum' started by eddiewww, Jun 7, 2003.
  1. eddiewww
    eddiewww
    Nov 14, 2002
    460
    46
    Blackheath, SE London
    +137
    Hi Guys,
    Not entirely sure this is the right forum...but i'm sure somebody can answer me..
    I have a Sony P800 and decided to try out the MP3 player... i never really used MP3's before and so don't have a huge amount of knowledge so excuse me if it sounds dumb !.... I dowloaded a couple of trackes...but the 16Mb memory stick cant hold more than one tiny one... i thought that if a reduce the file size then i'll get a drop in quality, but they will fit on until i get a bigger card, but i cant seem to find something that will reduce the file size...at least i cant see how to do it easily.... there must be an easy way !!
    any ideas guys !
    cheers
    eddie..........
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Have a look a one of the many MP3 Jukebox programs around. Also 16MB is not huge but should fit a few tracks on!!!
    PS probably a good idea to get a bigger card anyway, does P800 use shared memory, if it does all your pics and movieclips will be taking up space!
  3. eddiewww
    eddiewww
    Nov 14, 2002
    460
    46
    +137
    cheers m8
    i will have a check and see what i like...any recommendations ?
    eddie...
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,930
    2
    167
    Birmingham, UK
    +9,664
    There are loads of MP3 resources about.
    The 'standard' bit rate is 128mb/s though this is not CD quality. At 128, you get about 1 minute per meg.
    A lot of poeple now capture at 160, 192 and up.
    Typically you could fit maybe 9 minutes of 192 on 16 meg.
