MP3 DVD's?
S
seekdestroy16
Is it possible to play dvd's with mp3's loaded onto it on a portable mp3/cd player?. If not, is there a portable cd/mp3/dvd player out there that supports mp3 dvd's?. I want to load like 4.6 gigs of music onto a dvd and play it on a portable player....that would be alot of music anyways.
B
Biskitboy
To play a DVD you will obviously need er um..... a DVD player.
You'll have to do your research into which ones will play MP3's but remember you'll likely be lugging round a big bit of kit (...screen!) which usually will have a relatively short battery life compared to an plain old MP3/CD player.
Let us know what you find and how you get on.
Toasty
biskitboy raises a good point, you maybe better off getting a 6Gb+ MP3 player and transfering the mp3's from your DVD to that.
B
Biskitboy
GeoffWork said:
Also bear in mind that you cannot copy any purchased iTunes tracks as MP3.
Never used iTunes but can you not burn to CD then rip back to MP3...?
S
seekdestroy16
iTunes is a very good music program. It's totally free and there is no iTunes Pro or anything that costs money like Winamp and Winamp Pro. Go to www.apple.com/itunes to download. In itunes you can rip your cd's to mp3 format easily. You can burn either mp3 cd's or audio cd's in itunes aswell.
Well I knew that, but who says I need to purchase music off itunes?. Right now it's legal in Canada to share music, so there's no need to be all paranoid about getting sued (unless your american).
