MP3 DVD jukebox disk
Discussion in 'Blu-ray & DVD Players & Recorders' started by MP3jukebox, Oct 27, 2004.
  1. MP3jukebox
    MP3jukebox
    I have made a DVD-RW disk with 475 .mp3's on it... Cool.
    I have a few DVD players scattered around the home... Also cool.
    They will all play back the .mp3 files and shuffle them. Yeh I know - cool.
    But none will play more than 299 files. Either in shuffle mode or by jumping to the next one... Bummer.
    Are there any (cheap) set-top players , in the UK, that will play back this many (or more) .mp3's
    I guess its' a directory file count issue of some type.
    If so, are there any players that will play all files in multiple directories. My current ones will only play from inside each directory.
    Or, has anybody brought out a solution to this... e.g. a piece of software that makes .mp3's into a DVD Jukebox?
    The key here is random or at worst shuffle play back.
    Thanks in advance
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,860
    2
    In a secret location with Jennifer Lawrence
    +9,721
    Welcome to the forums.
    Post moved to DVD Players forum. You may get more player specific replies there.
