MP plays a black screen
Discussion in 'Desktop & Laptop Computers Forum' started by DaveP, Jun 20, 2005.
  1. DaveP
    DaveP
    I must have done something but I don't know what!
    If I use MP10 to play back MPG recordings (including DVR-MS) I get a very dark screen along with the sound track. They play back fine in Media Centre.
    I have changed the Codec using DECCHECK and it's still black.
    Has anyone had this and fixed it? MP10 is not something you can uninstal, sadly!
    Dave
  2. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    This might sound odd but check your display properties.. It sounds like you have told it at some point that you're using 2 monitors. Change it back to 1 screen and it should work with no probs.
  3. DaveP
    DaveP
    You may be onto something there. I did change primary monitor the other day to test the pj. I did change it back but maybe MP has got confused. I'll rig up the pj again tonight and see how I get on.
    Dave
  4. DaveP
    DaveP
    Sir, you are a star. Go to the top of the class!
    My Display properties were confused! A couple of OKs and MP is fine again!
    Many thanks
    Dave
