I have just installed Daemon tools lite, and have created a .mdf image of a DVD film. For some reason, Daemon tools would not let me make an .iso file, so I had to make a .mdf instead.
When I tried to import the file using the MovingPictures plugin, nothing seems to happen at all. It doesn't even try to find matches, it's like it doesn't even see the file.
The message at the bottom of the screen is "scanning local media sources (1/1)" greyed out.
Is there a way to get the movingPictures plugin to work with image files?
Any advice is greatly appreciated - thanks!
