moving xbox game/data to another xbox
Discussion in 'Xbox One' started by sheriffwoody, Jul 15, 2015.
  1. sheriffwoody
    sheriffwoody
    Oct 7, 2010
    7,456
    +1,533
    i am giving thought to possibly buying this:
    Xbox One 1TB Limited Edition Forza Motorsport 6 Bundle Games Consoles | Zavvi.com
    as it is double the storage, "limited edition" and comes with forza 6, which i will be buying anyway if i upgrade to a new xbox or not.
    question is, how easy, if at all, is it to move all of my games from my current xbox one over to a new console? or will i have to install them all again as new games? how does that work for digitally downloaded games, will i lose them if i move to a new console?
    thanks
  2. King Tones
    King Tones
    Oct 18, 2007
    36,945
    2
    In The House Of Flies
    +18,395
    Use an Ext USB HDD and move everything to that and then plug that into the new one.
    If you want to double your storage you can do that with buying the above, you could probably get a 2TB Drive for about £60 and then get Forza 6 for about £40.
    With Ext HDD its very easy to upgrade storage or use it to transfer all games.
    • Like Like x 1
    • Thanks Thanks x 1
    • List
  3. Kingster IOM
    Kingster IOM
    Jan 6, 2006
    293
    28
    Douglas, Isle of Man
    +50
  4. King Tones
    King Tones
    Oct 18, 2007
    36,945
    2
    +18,395
  5. sheriffwoody
    sheriffwoody
    Oct 7, 2010
    7,456
    +1,533
    currently i am not using an external hard drive - i just wondered if there was a way to transfer game data over from one xbox one to another, without the use of an EHDD.
    however, it appears the use of an EHDD is going to be the simplest way, so will probably just buy one of them and use that instead.
    thanks
  6. King Tones
    King Tones
    Oct 18, 2007
    36,945
    2
    +18,395
    It has to be USB 3 and minimum 256gb I think....
  7. Lostsoul 301281
    Lostsoul 301281
    Jan 23, 2007
    6,434
    7
    +1,815
  8. Waynej
    Waynej
    Oct 4, 2004
    8,264
    Wales
    +1,370
    It is quick and easy to move games between consoles using a USB3.0 external HDD. Without an external HDD you can re-install disc games to any XB1 console directly from the disc. As for digital games, these are not lost, you will always own them and they appear in My Games & Apps under the Ready to Install section off to the right.
