Moving vertical lines on Sky?
Discussion in 'Sky Digital TV Forum' started by Scapegoat, Jan 17, 2005.
  1. Scapegoat
    Nov 19, 2004
    I have read the long thread about vertical lines, but this seems to mainly be associated with Amstrad boxes and fixed rather than moving lines.
    I used to have a Phillips 32" 100Hz w/screen TV with an Amstrad standard Sky digibox. I had no problems with 'ghosting lines then' (just BIG problems with Philips and dis-colouration in the corners of the screen).
    Eventually I get the set changed to a Sony KV-32NX100U (expensive beast, but as the shop exchanged at no additional charge...). This is when I started to notice the moving vertical stripes.
    There are two of them and they move left to right. Only really visible when on the blank blue screen when switching channels.
    I have since switched to Sky+ (Pace V2) and they are still there.
    There is no RF aeriel connected to either the Sky+ or the TV, and I have snipped the cable in the SCART lead to no avail.
    Its not the TV though, as on its own with just a DVD playing, its fine. it might just be a factor of the TV and Sky combined.
    Any ideas appreciated. Not a big problem as its barely noticable.
