Moving TV from Northern Hemishere to Southern Hemisphere
Discussion in 'General TV Discussions Forum' started by rob5068, Aug 17, 2002.
  1. rob5068
    rob5068
    I have a Sony Trinitron that I moved from US to Australia. Apparently, I need two conversions: 1. NTSC to PAL format and 2. A method to bring the magnetic field of Southern hemispere into sync with TV design-picture appears to need degaussing, but the cause is the reversed magnetic field in this hemishere.
    Does anyone have experience with this problem?
    Rob
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Although I have no experience of this myself, I'm not surprised with the problems you are experiencing. CRTs are always set-up in the factory for a particular global region. By all means try degaussing... but I doubt if you'll ever achieve total satisfaction. Aside from the NTSC to PAL conversion, is there a voltage difference in Oz to contend with too??
    Standard advice is to always buy a TV in the market where you intend to use it. Sorry I couldn't be of more help.
  3. kiwiranger
    kiwiranger
    Bad idea all round. Anything bigger that 14-20" and you have visable problems. I took my Sony 14" back to NZ from Pom-land. I should have saved the luggage space. Picture was acceptable, but sound formats and reception range was horrible.
    Also, you're going to need a transformer too, to get from stateside 110 to Aussie 240.
    What was so good about this telly that you had to bring it with you?
    Chris 'kiwiranger' Parke
