Moving to the UK: Can I use my Denon 3803?
Discussion in 'AV Receivers & Amplifiers' started by dvsfore, Aug 22, 2005.
Tags:
  1. dvsfore
    dvsfore
    I'm making the move to the UK from the States. I have a Denon 3803 running
    120 V / 60hz. I bought a voltage converter for 220 V, but I was told that it still may not working since its frequency is at 60hz instead of the standard 50Hz?
    I also have a Denon DVD-1600 that is running the same - 120 V / 60Hz. (I'll only use it for my own DVDs but would need a multisystem TV (NTSC/PAL)
    With both running at 60Hz freq, are they useless even with a voltage converter?
    Thanks in advance.
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    If you have powerful enough stepdown transformers for them all, they'll work without problems :smashin:
    Nope, I run many 60hz appliances that were designed for use only in the US over here without problems.
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,443
    United Kingdom
    +1,820
    Why not just sell yours in the States and then buy a new one over here, saving yourself the hassle of using stepdown transformers. May as well put the money you'd spend on the transformers towards a new Amp and DVD player.
  4. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I have used some old 240v 60hz gear in the past (not hifi) and it really buzzed quite loudly.
    I second Jase's idea and sell your gear in the states and buy new over here.
