Moving to New Zealand - is TV compatible?
Discussion in 'General TV Discussions Forum' started by melchizedik, Sep 2, 2007.
  1. melchizedik
    melchizedik
    Jul 27, 2003
    I have a Sony KDL-40W2000. Can someone tell me whether it will work in NZ. I understand that they have PAL, but use PAL B/G as opposed to the UK which uses PAL I?
    CHeers
    Tony
  2. justind
    justind
    It probably won't work in New Zealand, as it has been built to work in the UK. When you tune it in it will only pick up sound only or black and white or nothing! The freeview tuner probably wont work either. But it will work with Sky (through scart or HDMI) or a seperate box plugged in. You may also want to check the voltage etc
  3. cossie
    cossie
    Jul 19, 2005
    264
    28
    +44
