Question Moving to Australia - will they work?
Discussion in 'General TV Discussions Forum' started by mortc002, Jul 17, 2018.
  1. mortc002
    mortc002
    Feb 15, 2010
    Morning all,
    I'm not sure where exactly to post this, however, I am moving to Australia for a couple of years this Autumn and want to know what if any of my TV's will work.
    I'm assuming that Digital terrestrial won't work, Netflix will (Aus version unless I get a VPN) and obviously, anything I put in HDMI (Australian Sky equivalent perhaps - not that I plan on getting this)
    As I only need to take two of the three I am trying to establish any gotchas I need to consider and which are best to take
    Model numbers below and any advice appreciated
    Panasonic TX-50CX680B
    Panasonic 50EX700
    Samsung UE65JS9500TXXU
    Chris
  2. Kend3591
    Kend3591
    Dec 23, 2017
    156
    28
    Southampton
    +86
    Australia has DVB-T and so your TV's should work. There is Fox which is Sky by another name.
    Having lived out there I should point out that the free to air TV is pretty average at best.
    Worth checking your TV model numbers and see if they have been sold in Oz. I shipped everything via container, if you don't have original packing then I wouldn't take it as the journey can be fairly traumatic for fragile goods, 42 days on the boat for East Coast and transiting the Southern Ocean can make for drama if not properly packed.
  3. mortc002
    mortc002
    Feb 15, 2010
    Thanks for this. I don't have the original packing for any of them so will need to explore what is possible for these then. I'll check if they were sold but sounds like if I can get them there in one piece I will be ok!
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,311
    2
    137
    Airdrie, Scotland
    +1,095
    Having been a Merchant Navy Radio Officer for ten years and knowing what the seas can be like, I would strongly advise that you take heed of Kend3591's warning. If you don't have the original packaging I wouldn't give a large screen TV much, if any, chance of surviving that journey.
    Whatever your decision, best of luck and enjoy Aussie. :)
    Martin.
  5. mortc002
    mortc002
    Feb 15, 2010
    The vultures (family) are going to be very pleased with me leaving them behind! Better that then broken tv's on arrival!
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,623
    Redditch
    +4,208
    The tuners won't work unless the firmware is upgradeable as they don't use 8 Mhz tuning blocks. They should work OK using an external source bought there. The old Topfield pvrs could be reflashed with Oz firmware, unlikely that's going to work with a European model.
    If it was New Zealand then they may well work
    Australian and New Zealand television frequencies - Wikipedia
  7. mortc002
    mortc002
    Feb 15, 2010
    Thanks for this. Inbuilt tuners don't really matter but this is good for expectation setting
