Moving SKY cables outside property
pats02
I want to put new TV on different wall in lounge. I dont think I can use interior satellite extension cables inside the room as fireplace between where my Sky box is currently and where I want to put new TV. Also Sky cables come into building independently, at two different points and then go under carpet which is glued down. My question is could I pay a Sky engineer to put two new cables from dish to enter the building at different wall, where I want new TV to go. My wife doesnt want wires to be noticeable above fireplace - mantelplace.
Any help appreciated
JayCee
Just contact any independent Sat installer in your area and ask for a quote.
I'd imagine you'd wait a while for Sky to do it due to the pandemic backlog.
taposh
Depending on whether you currently have or will want SkyQ.
I had same issue re: new TV. As part of SkyQ install I negotiated new cable lay down as part of the package for free. Used tactic SkyQ was redundant in current cable location so needed new cabling to UHD TV in order to justify the SkyQ upgrade.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
