Htfanboy
Established Member
completely wrong with the missinformation of having the heights in line with the fronts. another forum has debunked this fact and its all based on angles. they recommend 30-35 degrees.I'm not an Atmos expert - I decided that my space wasn't right for it - so I will defer to others here - but I believe the general view is that front heights should be above and in line with your Left and Right speakers..
this is from the top view like the above Dolby guide. and its also specified in the dolby atmos for home theater guidelines pdf which i can show you if you want.
Edit: Seems I need to slow down before I post comments. I can write a bit quickly before I notice some things.
