moving part(s) inside Quad 909
J
jon7226
Quad 909 arrived today. Noticed movement from inside case - not a rattle but rather a dampered movement. Is this usual - are some parts suspended inside? My 606 does not do this
thanks in anticipation
Ianfromnotts
There was something similar to this on Audio Asylum a few years back suggesting the bolt that held the mains transformer in ppace had worked loose and to remove the case to check.
Guess what yuou do depends on the terms on which you bought it but what ever it doesnt sound right to me so internal investigatio or return seem appropriate depending on how you bought it
indus
I've got two 909's and have often moved them around and have never noticed any sound/feeling of something moving around inside.
