I wonder if any one could point me in the right direction please?
I have just moved my Sony Home Theatre system from one room to another and i have a problem with my Subwoofer.
The old Amp to Sub lead was too short so i bought a 3m Phono to Phono Lead, which on the packet it says 'carries video picture from DVD to TV,' to replace the other cable.
The problem I have now is that when i turn the Amp off and leave the Subwoofer on it hums, and the volume of the hum goes up and down. When i unplug the new phono to phono lead it stops. When the amp is running i have no problem with the sound.
I have tried a temporary replacement with an old 1m phono to phono lead with yellow boots on, which i assume is for a video signal? Again when i turn the Amp off the noise starts. When i unplug the lead it stops. It is still like this if i only plug the end into the Subwoofer only and not into the Amp - it still hums.
My questions is am i using the correct lead, as in my Sony Operating Instruction booklet says the lead between the Amp and Sub is a Monaural audio cord, which searching on google does not tell me much!
Any advice would be gratefully received.
Paul.
