Moving Line When Playing DVD's
Discussion in 'Plasma TVs Forum' started by Ticsmon, Nov 7, 2005.
  1. Ticsmon
    Ticsmon
    when playing dvd's on my PWD8 there is a vertical line about 3 inch wide the length of the screen that moves from right to left slowly, it does it when paused so I'm guessing its a connection problem?
    Anyone come accross this and if so how do I get rid of it? :confused:
  2. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    are you using cheap cables??? thats the usual cause for problems like that
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    sounds like a player problem to me, what's the player, how old, try s-video and see how that looks if you are on component, try another player if you have access to one.
  4. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    842
    +38
    I used to have this issue way back in the day when DVD first came out - it is something to do with either the cables or the output settings!
  5. URL
    URL
    Oct 22, 2003
    1,333
    +54
    ...disconnect all other signal cables to the screen - is the line still there?
    Bet its gone now!
    DJ
  6. Ticsmon
    Ticsmon
    its a Panny scht 840 dvd/cinema system 2 weeks old
  7. Ticsmon
    Ticsmon
    got a tech link 3meter cable from av sales going from the panel to the digi box, a hitatchi 1.5m scart from the digi box to the dvd and a 3m van damme vga to 3rca going from the dvd to panel?
