moving house and sky with me...HELP
Discussion in 'Sky Digital TV Forum' started by didgit, Jun 27, 2004.
  1. didgit
    didgit
    I've had sky+dish installed a couple of month ago which worked finebut I have now moved house and taken the sky box with me and advised sky, the provlem is that I cannot get any signal what so ever. I am using an old dish with a new LNB (as I thought could be the problem) and a new cable but every time I turn the sky box it tells me "no signal received" I've checked the signal test in the menu and it's not coming up with any readings at all and from what I've read I should see some kind of readings ??? my neighbours have got sky so the area is not an issue.
    Can anyone make any suggestion ? I'm concerned that if I get Sky to come and fix it it's gonna cost me a fortune.
  2. John
    John
    Dec 13, 2002
    11,194
    +2,826
    when i moved house , SKY charged £50 for new dish / lnb and 3 runs of cable ,(2 for + , 1 for second box)
    as to whats wrong with yours ?
    -Dish pointing in right place (obvious one but had to ask :D )
    -2 runs of cable from quad LNB to box ?
    might be worth just getting sky out .
  3. bobbles
    bobbles
    you have to be pretty precise with the dish position. With the sky install you get a free dish, cables etc and all the work is guaranteed. You can not really complain at £50
  4. didgit
    didgit
    thanks for the advice, I thought I could set it up myself but obviously not :eek:(
  5. Fernsehman
    Fernsehman
    It's a trivial DIY job, provided you understand what you are doing.
    Dave Sullivan's caravan site explains how.
