Moving Fusion to new Mac
hutch
As the title say really I want to move Fusion which is installed on my MacBook onto my Mac Mini is there an easy way to do it?
Im not bothered about transferring the VM as im doing a fresh XP install on the Mini I just want to transfer Fusion and cant seem to find anything on the net about it apart from using Migration Assistant which I dont want to do.
alanrob
Established Member
Isn't it just a simple case of copying the application over to the other machine?
If it does need to install other stuff then download it again and install it on the Mini and input your serial number again.
Also, your VM's should be in the Virtual Machines folder in Documents.
hutch
I honestly have no idea, will give it a try now :)
hutch
A straight copy of the app didnt work so ive redownloaded to the Mac Mini and used the same serial number and its worked fine :smashin:
hutch
Got XP installed but AnyDVD is running like a dog through Fusion so its on to a Boot Camp install tonight which I really wanted to avoid :(
Its seriously about time Apple added Blu-Ray support to OSX its a joke that its not yet available :thumbsdow
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
