Moving Firestick remotes between sticks and TV's
Hugo Danner
I have had several Firesticks now.
My first Firestick 4K was bricked and replaced.
I kept that remote that research tells me is an "Alexa Voice Remote " with volume controls, but no channel shortcuts.
My second Firestick 4K came with the newer Alexa Voice Remote that has the channel shortcuts.
So I had two 4k Firesticks for while.
My roomates Firestick 4K died. So I gave my second one to him. He used his old remote.
Since I had 2 remotes and only 1 stick, I programmed them both to work with the same Firestick. For a couple of months I moved the one stick between my 4K Seike 39", and my 720 RCA 34", but because the RCA remote was lost, I used the IR volume controls on both remotes with it, and adjusted volume on the Seike 4K manually.
I got a new Firestick Lite since the RCA was only 720p, and the 4k would be wasted. Plus...cheap.
I'm trying to use the old Amazon Voice remote with the Firestick Lite, but the setup can't find the code to control the power and the volume now. I know this remote CAN work with this TV, because it worked fine with the 4K stick.
How can I get the IR to work with the RCA again?
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
