Moving data to new disk
Discussion in 'Satellite TV, Sky TV & FreeSat' started by philthyanimal, Jul 27, 2004.
  1. philthyanimal
    philthyanimal
    I don't suppose there is any way of moving program data off my old sky+ HDD to a new one?
    Just thinking of sticking in a 120gb drive, but i've got stuff on the current disk that i would hate to lose(all of the mighty boosh)
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    You have 3 options.
    1. Copy the programs to tape/disk using the copy option
    2. Watch them all before you do the swap
    3. Keep them on there and swap the disk back when you have time to watch them
  3. philthyanimal
    philthyanimal
    How do i use the copy option to move them to disk?
    are you talking about moving them to dvd-r?
  4. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Not sure as we don't have any external recording equipment hooked up but I believe if you go into the planner and highlight a recording, there is an option to 'copy' it.
    I suspect this will be via the scart socket.
    Can't see why you shouldn't be able to do this to DVD-R.
  5. philipb
    philipb
    Mar 6, 2002
    1,985
    63
    Swindon
    +132
    To copy go into Sky+ planner, select the recording(s) then press the red button. You'll be prompted to switch on the VCR etc, press select and away you go. Analogue transfer of course to DVD via SCART or s-video. If you can use the TV scart for RGB quality.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    There is no way to move data from a SKY hard drive to another hard drive and keep it intact to a such a point that it can be read by SKY+. SKY+ uses a slightly tweaked FAT file system along with a proprierty RASP layer created by NDS. I did read on another forum someone attempted to copy the drive to another using Norton Ghost but it couldn't do it.
    As others have indicated you may have to settle for exporting the programming onto VHS or DVD via the usual analogue outputs.
