Moving big files to ps3 question
Discussion in 'Playstation Forums' started by Ethan2000, May 3, 2007.
  1. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    Thanks in advance for any help or info:
    I have checked the FAQ and done a search, but what im after is a little advice. I have been converting video files from my pc into MP4 and they work fine and in good quality, but now I have some that are bigger than the capacity of my 1gb memory card. So I have 2 questions really.
    1, What size memory card (how big) will the ps3 recognise ?
    2, Or should I look at an external hard drive (I presume a usb2 one would be ok?)
    Or if you are using a better (read cheaper) way or moving files to view on the ps3 I would be very grateful of any help.
    Cheers Ethan.
  2. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    Think external HDD may be a good choice anyhow.
    You could always burn them to a dvd.
    Also the PS3 can play mpeg1 video.
  3. RunDMC
    RunDMC
    Dec 17, 2005
    624
    28
    Glasgow
    +36
    Agree that a cheap HDD would be a good route anyway, but I use a 2GB USB stick with no issues at all. I don't think there'd be any limit to the size of disk, only the file (4GB cap per file on FAT?). Anyway, with 4GB sticks only £20 or so, it is quite a convenient way of file transfer.
  4. Waynej
    Waynej
    Oct 4, 2004
    8,150
    Wales
    +1,337
    I know streaming is not yet a feature but if you can transfer the files to a memory stick surely you can easily some how transfer the files to the PS3 over the network?
  5. booth1976
    booth1976
    Dec 12, 2002
    829
    +13
    Do pen drives work fine with the PS3?
  6. lmaolmao
    lmaolmao
    Nov 22, 2005
    2,409
    63
    +182
    all usb mass storage devices i have tried, worked.
    for transfering files over a newtwork try redkawa fileserver.
    www.redkawa.com
    dont know how fast it is with big files. ps3 has a 4gb filesize limit for mp4s.
    mpeg1 video is an outdated codec now.
  7. booth1976
    booth1976
    Dec 12, 2002
    829
    +13
    If pen drives work I'm thinking of buying one for £17.99 from play.com. Will be easier than plugging my PSP into the Mac then taking out the memory stick to put into the PS3.
  8. 6950rpm
    6950rpm
    May 26, 2006
    149
    +10
    If you have network access why bother trying to copy the files across the network? Why not just play them over it?
    I use both Twonky media server and Tversity on a cople of PCs I have in the house to serve up content to the PS3 and find it works exceptionally well. Couldn't be doing with faffing around copy files all the time.
  9. twobells
    twobells
    Dec 2, 2005
    412
    +8
    What network solution are you using to stream?
    I have the 200mb 'HD' power bridges from Panasonic which stream in real terms at around 20mps.
    tb
