A andyv3 Guest Apr 27, 2007 #1 if i move a sky+ to another tv with out a card will i be able to watch the recordings
BruceH Established Member Joined Dec 29, 2004 Messages 260 Reaction score 9 Points 54 Location Weston-super-Mare Apr 27, 2007 #2 no. The raw stream from the satellite is saved, so the card is needed to decode it. Also the card enables your Sky+ access which allows you to record and playback.
