Moving a sky box to another room?
Discussion in 'Sky Digital TV Forum' started by mickyc1, Sep 5, 2004.
  1. mickyc1
    mickyc1
    Sep 5, 2004
    38
    hi all, im new here so go easy :smashin:
    iv moved rooms and the sky box is in the old room, with the dish just outside that window. i dont know what i have to do to move the dish as i dont have ebough cable to move it down to the new room. what sort of cable would i need and what sort of connector would i need? would i need to ring sky or would any1 be able to do this and save much needed £££
    thanks in advance
  2. Fernsehman
    Fernsehman
    To move the dish, you'll probably need a 13mm spanner, electric drill, 10mm masonry bit, suitable expanding wall bolts and a satfinder meter (or a lot of patience).
    Be sure to use proper satellite cable to reconnect the LNB to the Digibox and weatherproof the connection.
  3. mickyc1
    mickyc1
    Sep 5, 2004
    38
    i meant move the box :oops: i only realised there now i had made that mistake :censored: any1 help :lease:
  4. r4nd0m
    r4nd0m
    If you don't want to move your Skybox, use the 2nd RF output which you can send to another room and using a DigiEye (samson make them) you can control you Skybox (IR)from the remote room with only RF cabling and your existing remote.
    r4nd0m
  5. cinesom
    cinesom
    Aug 30, 2004
    30
    Go and buy enough meters of satellite coaxial cable to join the dish to the new place for the satellite receiver, two "F" connectors, connect one end to the dish and the other to the satellite box, hey presto. Or do as r4Ndom suggests.
