Moving 4805
Discussion in 'Projectors, Screens & Video Processors' started by maverick177uk, Mar 24, 2005.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,779
    103
    +482
    I've got my PJ attached to the ceiling through a joist only thing is that upstairs I walk over the joist and in time the PJ drops a few inches and this obviously means that it drops on my screen, is there any way I can tighten it up without damaging it?
  2. braiden
    braiden
    Feb 9, 2005
    676
    +47
    what mount have you got maverick, mine has alan key screws that tighten around the ball joint in the mount once it is set in the desired position. Funnilly enough I used to have the same problem then I found I could tighten mine and it hasn't happened since.
  3. beecee
    beecee
    Dec 8, 2003
    2,043
    Kirkcaldy, Fife
    +272
    if your joist drops a couple if inches then i dont think you should be walking on it, :confused: if i read your post correctly,....
    if its your mount? that drops then its not secured properly, and in time your beloved PJ will fall.... :thumbsdow
  4. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,779
    103
    +482
    Forgot about alan keys will try this hopefully will work, cheers :)
