MovieTyme Question.
Status
Not open for further replies.
I'm thinking of ordering some games on MovieTyme but I've noticed a lot of the PS3 titles are NTSC, will this still play on my UK PS3?
kendoll
Yes they will if you are using an HD connection (or if your TV can accept NTSC SD signals at the right frequency).
Please try to use the search function as this has been discussed on numerous occasions.
Closing Thread. :)
menz83
Yeah they will all work fine as all games are region free. However, if you are using an old CRT TV then make sure it supports the NTSC colour scheme otherwise games will play in black and white! Most modern CRT's do support both PAL and NTSC via scart/composite so I wouldnt worry too much. A good way to test is by downloading some demos off of the Jap/US playstation stores. If they work in full colour then you will be safe in the knowledge that all titles from Movietyme will work fine.
Status
